Smarty and tow numbers?
speed limiter
Edge Juice Hot Or Not????
Can I get some real world numbers?
Has anyone had this long enough to give me some towing numbers? All I am really hearing right now are power and smoke on the street.
EGT and MPG numbers would be awesome.
Thanks.
Eric I did post mileage increases for towing. A hotshotter will be doing mileage testing when he returns from vacation on 8/14
yogibear should have his smarty by now. yogiibear is always driving Oo.
Thanks.
Eric, I'n not sure which truck you have the SMARTY on. I have one an a 01. 5 2500 QC 6spd. I tow a 16ft construction trailer loaded with tools and my 30 ft camper trailer. Both trailer weigh between 10k-11k. I have not been able to push the EGT's above 900 even going up the mountains leaving it in high gear. I just towed my camper to Maine and back, all secondary roads and averaged 16. 9 mpg hand calculated. AND the power is just soooo much fun... Hope this helps. By the way, empty on the interstate with cruise set around 75-80, I get 19. 8 mpg. :D :D
Out here in the west, where we have REAL mountains, and not "speed bumps", :D I get about the same 16+ MPG with the Smarty towing our 24 ft fiver (14,500 GCW) as I did when all I had was the Edge Comp. Biggest difference is, I have lots more power on tap with both the Smarty AND the Comp, plus the behind-the-wheel adjustability of the Comp to enhance the Smarty's programming.
Empty, I hand calculated 22. 2 MPG with the Smarty, in mixed STEEP mountain driving mixed with level freeway and city driving.
It really mostly depends on WHAT Smarty setting you use - and how you control that right foot! :-laf
03 Ho
ECappleman said:
Looking for numbers for my 03 HO.
Thanks
this was an 03 ho
my neighbor saw the best fuel economy on the 60 hp vs 30 hp software
weight camper and trailer 17K
stock 11. 2 mpg towing
30 hp program 12. 9 mpg
60 hp program 14. 7 mpg
egts reduced 100+
So if I understand correctly, you uplaod whatever program you like to run and if or when you need to go in for service just dump the stock program back in?
yes that is correct :)
Bob,
Can you change it on the fly? I know it doesn't have a moniter like the outlook but with the bullydog you can still plug it in and change it. Is that possible with the smarty?
Thanks
Luken said:
Bob,
Thanks
No the ecm must have software installed to run... ... ... ... ... .
Bob
