I have the Smarty, but dont know how to use the high idle. . Would you gentlemen be so kind as to explain the process for me?
JT
Edit: if the RPM's dont jump to 1000rpm when you hit set, you dont have it enabled.
Must only work on auto trucks!
I have the newest Smarty programming and the high idle trick doesn't work on my 6-spd. Oh well... back to the yard stick on the pedal!
with engine running and in park, hit the cruise controll button to turn it on. . . then hit set. engine should jump to 1000rpm. then you can use the accell button to increase RPM's by 100rpm up to 1500. the decell will do the same, only lower RPM's.
