Currently running Marco's ECM and a Juice W/ Attitude that has been unlocked to have access to level 6. Having problems with the pre-set software on Marco's ECM and level 6 on the Edge. Levels 1-5 work fine. I purchased a Smarty Controller last week to re-program the ECM to level 8 to take out the timing of the ECM. I thought this would solve the level 6 problem and everything would be good, but I was wrong. The problem, I'm having is when the computer is set on level 6, and you start accelerating through the gears, by the time your in third or fourth and the turbo is beginning to spool and I keep pressing on the accelerator slowly, the power for some reason falls off or decreases. If you back off the pedal, the power returns. If you then begin to press down on the pedal again, the power falls off again and back on again when you let off the pedal. It's like past a certain point on pressing down on the go pedal, the power cuts out and then back on again when you let off the pedal. I'm at a loss on this. There has got to be somebody out there that has a Hot juice and the smarty controller for changing the ECM settings. Is anybody having problems on level six after chaing thier ECM's from a stock setting to a Catcher setting?????? Sorry about the long question.
