Smarty Jr and One Piece Drive Shaft best money spent
starting issue
Little injector help please
The two best things I have bought within the last six months are my Smarty Jr and the aluminum one piece drive shaft. The Smarty is easy to use and really helps with the power. The one piece drive shaft took away any vibration I had and it rides like a new truck.
Guages are next. . then look at dropping another $5-7k on a reliable transmission.
It would be very hard to give up the Smarty and I can now see what is behind me in the rear view mirror at 70mph with the one piece driveline. :)
Is the aluminum shaft as strong as the steel?
Why were some aluminum and some steel?
I suspect so. The aluminum tube is much bigger in diameter than the steel and the joints are bigger too.
I think the reasoning for not using alum is in part cost as well as being something new that existing engineering staff wasn't accustomed to.
Dog house diesel stocks factory mopar drive shafts.
If you have a manual transmission then things get a lithe more complex, search old threads on this for all info and part #'s.
