Smarty Jr Settings
Help removing the cat
Juice + Boost Fooler?
moonranch
I need help interpreting the "torque" settings on the Smarty Jr revo? The instructions say:
1-Stock, 2-Mild, 3-Soft(less than 2), 4-Light(less than 3)
From this, I assume that 2 would give the most throttle response, then 3 a little less and 4 a lot less. Is this correct? Or is it more like the regular Smarty where "less" means less "torque management" and therefore more throttle response on the higher number settings?
I believe you are correct. They added the variability to accomodate for different trucks and modificatons to lower smoke upon accelleration. I would like a softer torque management setting for when I am not towing to save tires and my throttle is pretty touchy at low speeds.
