Shouldn't hurt a thing, just the nature of the common rail. If your running stock timing your not getting much from the Jr as the timing is the main reason to run one.
Try reducing the tq management. TQ3 and TQ4 really reduces my rattle.
Timing rattle "Shouldn't hurt a thing"???
Tell that to the guy's whose motors are now in pieces.
If that were the case every 24V VP engine woul have died a long time ago. Even on advanced timing these CR's can't compare. A 12V at 21 degrees is really noisy and they live fine.
Diesels will rattle on ignition, its a fact. At an idle or just off idle the cylinder pressures are not high to worry about. Its when the rattle is gone and the timing advanced too much that the problems appear.
The lack of rattle and in a CR is a combination of emissions and NVH initiatives. Doesn't mean its bad for them until you push too much fuel in the advanced stage, but, thats a different discussion.
Smarty alone is not going to advance the timing far enough to damage an engine. Stacking and not understanding the fueling rates yields much different results though.
Apparently I missed the boat??? I thought the guy was asking about a CR. You are posting about a 12V, 24V VP, and CR, a "History lesson" if you will.
Another point I apparently missed is that this rattle is only on idle.
You must also be a mind reader, because I read none of this in his original post.
but even without it shouldn't be that noticeable.
What does an AD have to do with timing rattle? This will have zero effect on rail pressure in the demand modes where timing rattle occurs on a CR.
The point in older enigne timing was they all rattle, and they all live.
Thats because its a diesel and your going to get "timing" rattle no matter what flavor. The point is the rattle is not an engine killing thing, as you suggested. I was pointing out as others did that the rattle is not a bad thing and part of the design. There are certain things about these engines, 12-24-CR, that are common ya know.
Well, since the rattle is really only noticeable at idle and off idle it kinda follows. As injection advances the rattle dissipates or gets swallowed up in the engine noise. Kinda hard to talk about it when you can't hear it.
You also missed where he said the stock settings is the quitest of all and was wondering if the other settings were an issue with the noise. CR's are quiet at stock settings because of the retarded injection timing. Advance a little bit and it will get noisier because its a diesel, thats all we are saying.
The AirDog made a noticeable difference in injector noise. If you had one, or was around a truck with one, maybe you would know this.
almost all of the benefits appear to be hype by 99% of reports.
Combustion Knock is gonna be $$$$
and most of the time there post are helpful. Its so easy to put more into keystrokes then what really being Stated...
Rattle is common, but should be controllable,Combustion Knock is gonna be $$$$,I think Dieselduck, is talking more about CK then rattle. . I have Stated this MANY TIMES "CR does Not conform to Logic it Conforms to experience". Dieselduck AD & Cerb Are just like us, and most of the time there post are helpful. Its so easy to put more into keystrokes then what really being Stated...
