I have an issue that has come up regarding the Smarty on an automatic transmission. I never noticed it untill I replaced my slipping torque converter with the 5-Star converter ( that baby doesnt slip a bit! ). The issue I am having and wonder if anyone else has noticed is that the shift points are not where they should be and the shift into overdrive lock-up is very harsh and too early, you know it's locked up when the coffee is all over the floor. I will assume that the problem is related to the compressed acceleration curve in the ECM and the transmission shift timing is controlled by the mechanical throttle cable. If I load the stock software back in the ECM the problem is greatly diminished. I am left wondering if the Smarty is changing the shift points or if the reworked throttle progression is at fault and what could the solution for this be?
Has anyone else with an automatic noticed this or is it just me? I know Marco is a very busy guy but would it be possible to have a software version optimized for an automatic maybe less agressive on the first 1/3 of the acceleration curve so the shift cable could command the transmission pressures and shift sequence to be closer to optimal? Or maybe someone with better fabrication skills than I could make a box with offset eccentric cams that would move the throttle valve cable at an accelerated rate to better match the Smarty curves, kind of like the way a compound bow works.
I would not trade my smarty for all the tea in China but maybe it could be tweeked a little bit for the auto crowd. This is something I have been pondering for a while now, what do you think? Any ideas?
Regards, Mike
Regards, Mike
