Smarty Question
Help!!!
new stock injectors
Drewhenry
Greetings All,
I have a question about SMARTY settings I don't quite understand. For example SW#9 is 170hp + additional timing. Can the amount of timing in this setting be adjusted in REVO? Is the amount of timing in this setting equal to the default setting or #4 in REVO? I guess what I am asking is can I get more timing advance by using timing setting #4 in the adjustable options when loading Catcher #9 ? Or are the "adjustable options" only for even numbered programs?
Andy
no, once you choose to change the timing level (#4 being most advance) then all the catcher levels are timing.
The default softwares are timing/ no timing
If you need any specific help I do offer a toll free number.
I really hope all is good in Corpus Christi
Thanks Bob
Bob,
All is good in Corpus. We didn't get any rain or higher than normal winds from IKE. We did get some unusually high tides and rough seas on the beach. Galveston and Houston area got slammed!
To clarify my questions some(and I may be calling your 888#), will I be able to get more timing by adjusting to level 4 in REVO than I would using Catcher#9 with options set to default? This is a discussion I am currently engaged in with the dealer(and longtime friend) I purchased my SMARTY from.
Andy
yes buy incressing the timmong to level 4 ismore timing than the default setting. allso timing # 4 iffor the fuel econ seting. if i remember rite the default settings with the smarty are equivalant to #2 settings mild. Keep the rail pressure on the defult setting as te newer hpcr stock injectors dont like higher pressures.
step in if im wrong
