Engine/Transmission (1998.5 - 2002) Smarty, setting codes
2nd Gen Non-Engine/Transmission question on finding a live wire
Engine/Transmission (1994 - 1998) 14cm Turbo Exhaust Housing
It sets a P0602 (ECM fueling calibration error,normal with nonstock software) and a p1693 (DTC detected in companion JTEC module).
those are normal codes to have due to you having an edge comp and smarty. anytime a code is present in the ecm it will show up in pcm. Those two will always be there.
Never had the Smarty set a code due to ambient temperature.
At first my Smarty would set the CEL due to p0602. That was due to my truck having California Emissions ECM software. I sent it back to Bob W and I assume he re-programmed it to fix that problem.
Jim
Jim
Bob would have to speak up, but I think we all get 602 the info is posted in the smarty thread.
