Smarty SSR
Fuel leak!!!!!
Transmission cooler line o rings?
I read on Power Products Unlimited - MADS Smarty SSR 03-07 5. 9L Dodge Cummins Programmer/ Tuner that the Smarty SSR is not to be installed on a stock truck. This is their comment NOTE: THE SSR IS NOT FOR A STOCK OR EVEN CLOSE TO STOCK TRUCK! IF YOU ARE UNSURE ABOUT YOU OR YOUR TRUCKS READINESS FOR SSR GIVE US CALL BEFORE ORDERING!!!!! Is this really true?? Only thing I have done to my truck is I had the transmission rebuilt. And no I can say what was done other than I told them to put the heaviest duty parts in it. TC, VB and bands. Local shops here dont have anyone who I thought really specialized in 48re. So is this true that I shouldnt use it on my truck??
IMHO the stock trans and stock turbo are maxed out at stock power. You can get away with small power up grade on a stock truck such as the smarty jr. I won't even think of running a regular smarty (much less the TNT SW) on a stock truck. If all you have is a built transmission, then you are no where close to ready to run higher hp. I would also doubt that if you trans isn't build by someone the knows what they are doing, it probably won't take too much extra hp.
The ssr allows 4k rpm without the proper
Upgrades you will be sitting on a te bomb
Go to comp d to read more info
