darkhorse said:The gauges are a good idea even bone stock. As for the sw#, I don't think that's so important. All the CaTCHER soft wares yield about the same upper end power. It's the aggressiveness of the throttle that varies. Go for #9.
kshimizu said:I'm now experiencing the same problem as a couple others mention like below. I had a new injection pump and the retro lift pump done last December under warranty. I get the pause surge feeling while cruising on SW7. When I get on it it goes with no problem. Last night I turned it back to stock and it runs fine. I checked for codes and don't have anything of concern. I've run 5000 trouble free miles up until the past few days. Has there been a fix for it yet? Is it only happening on certain levels? I need help, I can't stand driving in stock mode.
SMoules said:I have owned a edge comp on my truck for 5 months now. I recently borrowed a smarty for a weekend from a fellow tdr member. I did not like the way my truck would fall on it's face after each shift but as soon as the rpm's picked up it would just shoot my truck forward. I also tried it with my comp on 5x5 and it seemed to take care of the majority of the lag if not all. If I had to choose between one or the other with no other mods I would keep my edge comp. Reason for would be the smooth power delivery from beginning to end of each gear and the other reason would be the adjustible power levels on the fly. P. S. Has Marco answered to this lag question yet?
Marco said:Gary,
what you've seen is normal.
The ABS ( tire height ) feature is VIN locked. You have to update the ECM with a not stock software in order to VIN lock Smarty. Once that's done the ABS feature becomes availabel. No VIN lock, no ABS - tire height adjustment.
When you take the ECM back to stock, Smarty returns the ABS to the tire height that was found in the ABS prior to changing the setting. As long as Smarty remains VIN locked the ABS setting is not changed.
Has nothing to do with the battery disconnect... .
Helps?
Marco
I've tried to keep up with this thread and more importantly on the surge problem, to which I have never experienced. Is this only happening with the auto trannies? I have never had any surge problems.
Marco said:Let's talk about the "surge" a few of you got with the CaTCHER.
It's a lot of time that we talk about that problem in a way or another.
I've been in contact behind the scenes with several guys. We've tried a lot of things; to no avail. :{
All I know today is that in some way it's related to something in the truck.
What? I don't know.
A member here went so far to swap both the ECM and the PCM with a buddies truck. The problem didn't move to the other truck. That means that the ECM & PCM are not responsible for that surge, nor is it the software per se. Sure enough from what I've gathered then higher the software # then more pronounced the problem. In other words, than less torque limiter than worse it becomes. I'm scratching my head...
Kshimizu had used Smarty for a while and then the surge developed all of a sudden after about 5K miles... What gives????
Since it seems impossible to determine the cause, maybe it's possible to work around it with the software?
Any volunteer?
I'd send update(s) for Smarty. All you need to do is to udate your Smarty with the test softwares and see how it works.
Anybody?
Thanks!
Marco
or do other competing similar enhancement devices also do it for some users?
IF the problem is NOT related to the normal/stock devices in the trucks, it seems logical to assume it is either coming FROM the CaTCHER/Smarty, or is due to it's effect upon the stock devices.
If other generally similar aftermarket downloader/reprogrammers do NOT create the surge, then what differences are there between those units and the Catcher/Smarty that are unique?
Is it possible that the aggressive responsiveness we buy the CaTCHER/Smarty for, is in itself the basic cause of the surge - perhaps due to the inability of random components in some trucks to smoothly accept and merge with the more aggressive programming?
Marco said:or do other competing similar enhancement devices also do it for some users?
None I know of, never heard about such a surge from fuelling boxes.
