Smarty...to add timing or not?
Torque Converter & VB Recommendations
max energy
I just put on Smarty, added new turbo and have run on #8 and now #9. I have been reading about what added timing does. I have the 50hp DDPs and want to know if added timing is the thing to do. It pulls harder and faster on #9.
Am I ok to daily drive at this level?
I would think you would be ok with the regular smarty sw with the 50 HP sticks, but if you are worried about it than go to the website and download the aftermarket turbo and injectors sw then you will be safe... it is my understanding that the even number tunes are designed to be ran with another timing box like the TST
also I think you are fine to daily drive on that level... i daily drive on my on 7 and 9 regularly no problems in the last 20K
i would run with timing. U will have lower egts, better mpg. If u get alot of timing rattle, download the aftermarket ingector softwares, they reduce timing just a little, but since u only have 50 hp injectors i don't know if u want it or not. Try both.
