I rolled 450hp/875tq on setting #8 at Diesel Thunder in Spokane, was very disappointed. When I added TST my numbers went down. I did not have my programmer with me
so I could not change to a lower/higher setting. Truck ran like crap all the way home, cutting out, no fuel?. .
This morning I hooked up Smarty and went back to stock settings, ran fine, although not the power I'm used to. I started adding TST, got up to 7/6 before I started loosing power, but truck did not cut out, ran like a thief.
After talking to BIG BOB / Jason B. , I removed the bolt from my banjo fitting on top of my rail pressure relief valve, started the truck and spewed fuel all over the place. I guess I found my weakness.
So to sum this up, I guess my #s are not too bad considering a blown relief valve.
Why I was cutting out with the Smarty and not the TST, I am not sure, asking for more fuel than the injectors were provided? Once I repair my valve I will try Smarty again.
