Smarty?
Quadzilla XZT and Smarty Jr.
Cleaned injectors, now miss, smoke, and throttle sticks!...
Can my smarty be used on my Dad's 07 Cummins to program high idle only, and will I still be able to use it for my programming or is this feature(high idle) only VIN specific?
If you have a S-06 you should be able to. Return your truck to stock, load any number into his, return his to stock and it should be there.
John
The Smarty will not turn on the high idle feature. (but some other programmers have that capability) That can be done however with a flash at the dealership.
Well crap. Mine doesn't even show that option. I have the s-06 also. I had to pay the dealer $75. :mad: #@$%!
Sorry for the misinformation then.
What about JR.
I have an 06 with a 6 speed. Does anybody know if you can enable the high idle feature on a manual using a Smarty JR. If so, how? My JR doesn't seem to offer the option. Thanks. Jeff
Fast Idle vs High Idle
My Jr just runs fast idle when it is cold. There is no option, I guess it just does it.
Mine will run high idle when it's cold also. I was wondering if you can set the fast idle using the cruise control with the
Smarty JR.
Jeff
