The last 2 performance upgrades that I have done both produced too much smoke. I'm talking about heavy black freight train like smoke. The first upgrade was a Catcher ECM that worked well but the smoke was way too much and I pulled it out. The second is a set of Don M's 1. 5 injectors and I have the same problem. Something is wrong with my truck. I have good turbo pressure at up to 38Lbs. and seems like excessive EGT's. The smoke clears up at about 20 psi boost but until then it's pretty bad. The engine doesn't burn any oil between changes. I have unhooked the pump wire from the Banks box and It made no difference in the smoke level. I run a constant 12psi fuel pressure at cruise with a Fass. The problem exists at sea level and altitude alike. No codes and idles smooth. Any help is greatly appreciated.
