Well, my 93 w350 dually sat for a year and wouldn't fire. I believe it is a fuel problem, but that is not the reason for this thread. In the process of trying to fix it, I tried to hook up a remote starter pushbutton under the hood to help in bleeding the high pressure lines. It was connected to the solenoid terminal and an insulated terminal on the fender connected to the battery (I believe it's the power to the starter relay, any way it was a more convenient constant hot).
After placing the key in the on position, and letting the heaters time out, I pressed the button. The negative terminal on the battery smoked and the truck now has no power! Not a single electrical component works. The starter never turned.
Looking at the schematics, there are several fusible links. What are the odds that I smoked all of them? By the way, I have no power in the fuse box on any of the bus bars on the bottom.
Does anyone sell a wiring harness or shoud I cut out all of the fusible links and install my own fuse box under the hood?
By the way, the previous owner appears to have already replaced some of the fusible links.
