Originally posted by A-bomb:
PowerWagon,
Please enlighten us... .
Pump timing seems plausable, but it appears to me the timing would have to be very advanced - accompanied by a power loss, epsecially under load. Also, since the truck has relatively few miles on it how could the pump timing all of the sudden change to the accute condition mentioned? Would'nt the smoke be black?
Actually, retarded timing causes blue or blue-white smoke. Advanced timing can contribute to more black smoke under load.
The pump timing can slip... Ask any number of TDR folks what happens - however, I doubt your timing has slipped... If it's off, it always was off.
What happens, is that when you go downhill, there's no fuel injected, and lots of cool air rushes through the engine, cooling the combustion chamber and then when you do hit the pedal you get smoke until the chamber heats up. This can be exacerbated by late timing, which tries to inject fuel past the point of maximum heat, resulting in poor burning and white smoke.
The overflow valve seems plauseable, but how exactly would it cause blue smoke instead of black smoke?
A faulty overflow valve holds no pressure at all in the galley of the injection pump, causing the fuel inside it to be alternatively pressurized and then under a vacuum. My guess is the diesel forms small bubbles, and the attempts to inject send non-solid fuel to the injectors, resulting in poor injection quality. Cavitation can happen easily enough when there's no pressure and the plungers are moving rapidly.
Understand, this is a guess on my part. But, it does not sound like an oil burning or turbo failure problem to me.
What do you think?
