Engine/Transmission (1994 - 1998) smokin
i recently adjusted the afc, got better power n response out of truck . moves very well. had other issues with batts changed out cables and connectors. clear up alot of issues . but my rpm's are still high at 1100 at idle 950 at load. tried adjusting low idle it would start at 750 but then when i run it, it climbs to those #'s. also low idle ios adjust all the way . it cant ngo no more.
checked banjo bolt in fuel return the spring was about 3/8's stretched it to just slightly over 1/2". now it smokes going up hill like to much to little fuel when i step on it . also put in a k&n air filter . oil, fuel filters changed transmission oil and filter changed trans adjusted. any ideas ? thottle linkage tight can adjusting linkage help to gain low idle adjustment?
thanx for any help :confused: :{
