95 3500 5-speed 3. 54 gears, that is a start. It would be kelpful to know if you are at high altitude or not, cold or hot, ETC. For it to be belting out the smoke something has changed from the factory settings. I would guess that at a minimum the cover has been off the pump and the star wheel is turned in a few or a dozen clicks. Someone may have slid the plate and the AFC housing too. Do you have guages? If so what are the EGT's like? Some more info would help us help you RJ.
