:{ Well, it happened today!! Changing the diffs and NV-5600 fluids and when using a torque wrench to do the final torque on the diff. cover bolts one snapped off. It is the one to the right of top center. I doubt it will leak, so I may not stress about it too bad. I wouldn't torque these things to 30ft-lbs, which has been addressed before. I just forgot.
I would have been fine if I had left things alone, as I torqued them to 25ft-lbs and then was going back through. Needless to say, I snugged the fronts and that was it. I will try an EZ out when I get a chance but may just see if it leaks and if it doesn't then screw it.
Don't let this happen to you!!! :{
