Competition Snow Performance Problems
Competition Edge Dyno Days What A Freaken Joke
Competition Tulelake, CA Sled Pull Results
Can't figure out why my pump is on constantly. I have checked the wiring probably ten times. If anybody has any suggestions I would greatly appreciate it. I do have the switch on a different fuse than the LED light and controller wire. But I thought that wouldn't make a difference seeing as how all the wires lead back to the control module.
Thanks
Ryan :confused:
You have the switch that is activated be psi? Did you check the it's not turned to low? I used shop air and a volt meter to set mine to turn on at 32psi and go to full power at 40psi. The wiring is pretty straight forward. If that's not it call Matt in the morning. He's a good dude and will treat you right.
Well figured it out with help of a friend, had the pump wire and wire that it connects to on the variable controller hooked to the 25 amp fuse, took those off, hooked the switch to the fuse and it fixed the problem. Guess I was thinking to hard about it, thanks for the reply.
Ran
