I just got back from my first trip running the water/meth. injection. I towed a 36' triple axel 5er from Ne. to Ct. , was grossing 24,680. No real long steep grades til I got to Pa. , there I had some 4 to 9 mi. 5 to 6% grades. Was running straight water, and it was cooling the egt's at least 200*, and water temps never got over 205*, ambient temp. was 84 to 86*. I'm real happy with it, egt's never got over 1050* when using it, and went to 1250-1275* without using it. I have Mat's 8 gal. tank mounted in the bed with the pump mounted on the frame just under, and ahead of the tank. I thought at first the 8 gal. tank would be really over kill, but I used up the first tank in about 350 mi. , but had to do a lot of adjusting on the Hobbs switch. It was initially coming on at about 22#, and secondary at 34#, now have it coming on at 26# and 34#, and should use less water. In the low altitude back there I was running 37-40# boost. I hope the next trip will get me in the mountains to better check it out.
Larry
Larry
