So many modules so few pics (and info)
How to tell when transmission is full nv5600?
Gear Oil Installation Tools?
I know this is getting redundant. It's time for some power enhancement and which way to go... ? Edge Comp, Zxillaraider, TST... .
I suppose they are all pretty much the same. Pressure, timing, and duration. I'd like to see a few pics of the gauge unit in the cab. Do they all cover the same parameters? Having the Edge just become available for the '04 305/555's is what is giving me the urge.
Feel free to continue the talk of the different modules and post pics. I think there are a lot of us still looking for that right product. Some of the websites seem to lack real hard core info.
Thanks Lads.
Attitude A-Pillar Mount
Here is mine.
With the pyro sensor installed the Attitude can display EGTs, Boost(questionable accuracy), engine temp, rpm, speed, backdown, load, intake temp, throtle %, baro pressure, lock and slip. Display can be set to show 1 to 4 items at a time. It displays the current power setting and will alert on speed, EGT, Boost and a couple of other alerts.
Benson said:
You guys are awesome. Now if somebody would just tell me which one to get.
Is this mod going to be for just a little "something" extra... Or maybe a building block for in 3 years you go crazy with a turbo,etc
Because there are many ways to go, But alot depend upon where you want to end up :)
Ohh yeah, PS - I VOTE TST POWERMAXCR!!!! Check my dyno page if you like
Hard to say.
I'll probably have it in one of the lower settings most of the time. But the fun factor may influence me.
I can't seem to find the actual specs on the different units. Is the TST the only one that doesn't increase pressure? Even at the higher settings? How difficult (and necessary) is installing the pusher pump?
As far as I know, the TST and the VanAaken are the only two that do not raise rail pressure for your model year truck... (not even on 9x9 on the tst, it does not even have the plug-in, thats why we stack a box for a little pressure)
And the pusher pump is not needed if staying on the lower levels... 4 or 5 and under
