I'll have a stab at it.
Upon speaking with a reputable organization which sells mod/high performance product for use on our beloved CTD, I was informed of the following;
The BHAF [or any high flow/high capacity assembly] benefits the latter truck [1994+] bc of the small factory assembly.
Adapting another filter assy to our truck is not necessary bc it flows enough air, more than the engine can use, unlike the latter trucks.
This company dynos trucks and found that the 1st gen engines produce the SAME HP with a CLEAN factory element as with out any element.
Furthermore, was told that the more air which enters the intake from within the engine compartment the less HP the engine can develop due to the fact that this air is much warmer [less dense] than air outside engine compartment. Thinner air makes less power. BTW, if you dyno your truck, do so on a cold day with high barometric pressure. Nos look better than on a hot day with say a low front passing through. [all other things being equal]
My school busses employ a very large air filter assy. We don't change them very often. Use the filter minder which monitors the amount of restriction. I'm told you don't want to mess with it till it's time bc the more you do the greater the chance of contaminating the intake with dirt.
I'm currently overhauling a tractor engine which had operated with the intake hose loose. The pistons are toast as well as the cylinder liners.
OUCH!!! Guess they never thought to perform PM. Good news for me, this job will pay for new truck stuff!
This is some info passed onto me, a rookie with the DODGE truck. Hope I didn't step on anyones toes here. Just some thoughts to pass along. I would recommend doing as much research as possible prior to any mods.
Speaking of mods... ..... I,m currently assisting in the conversion of a cat 3408 to run on alcohol!
Scott
