... as I was cruising down I-5. '92 automatic.
Cruise control set, and humming along... then it just dies. I didn't notice any stumbling or anything... just dead. I have been fortunate that I haven't had to do any major work on the truck since I got it 5 months ago, but that also means I don't really know what makes it tick, yet. Or in this case... what makes it NOT tick.
As our Cummins are mechanical, there isn't much that can go wrong to make it die and not start. From dinking around with it this evening, I am pretty sure it is a fuel delivery issue. I loosened the line to the #1 injector and turned it over and got some fuel, but no where near what I'd expect for this motor.
How 'bout a quick overview of the fuel delivery system? I know the injection pump feeds the injectors themselves and handles the timing of the system. Is there an electrical fuel pump in the tank that feeds the IP? The wiring under the hood is kinda scary... are there any electrical bits that would cause this? The shutoff solenoid could, of course. I assume it shuts off fuel flow unless it gets power, right?
Anything else I should be aware of before digging in... without a service manual?
Thanks!
