So what does this oil filter fit...
Couple questions on for the '95
was six speed availible in 98?
05016547AB, I bought two of them from the dealer today, are these correct, or do I have to go back and raise some h&ll... . I really do not want to use them if they are wrong. .
Mike #ad
'99 Ram 2500HD, ISB, 5spd,2wd, quad cab, Long box "it's a real long truck!" Drifwood, agate interior, after 14,000 miles, diesel fumes definitely do not make me horny!!!! "THE KLACKER!!!"
'68 Plymouth Valiant Signet 4 dr w/ turbocharged and EFI'd 225 slant six!
'67 Plymouth Valiant Signet 2 dr w/ a shoehorned in 440
'70 Dodge Dart Swinger, in full apart mode awaiting time to be worked on!!! Soon to have a bone stock 360!
Deepsix, that is the Mopar listed filter for all diesel applications. It is a paper filter. Most of the guys with the 24 valve are using the Fleetguard LF 3894 Stratapore. The one you have will work, but the other is better.
DEBEEST, 99 QC 2500, SLT, 4X4, LWB, 5 Spd, Rhino Liner, Mobil Delvac 1 5W40, Auto Trim Design Runningboards, Les Schwab Wild Country Radial APTs, ISSPRO Boost Gauge and Pyrometer
That is the latest and greatest made for mopar.
Don
"The Shadow" 2001 Dodge Ram SLT 2500 QC 5spd 3. 55lsd, Short Bed, Sport,Black, Camel/Tan Interior, Trailer tow package, Camper package, Infinity sound. Towing a 27ft Dutchman 5th wheel w/slide
IF YOU CAN'T RUN WITH THE BIG DOGS... YOU BETTER STAY ON THE PORCH.
Elba Twp, Michigan
Member Great Lakes TDR
So who is right, one guy says there is a better filter out there, and one says it is the best out there. Who is right????!?!??!?!?!
Confused already?
Mike #ad
I believe Fleetguard is CumMins part. Order the Strata from Geno's. The last post I think is saying that what you bought is the best thing from DC...
Deepsix is correct in that the last part of the Mopar filter has a 'B'. At least mine has it too. Must be a revision change.
KevinT- I believe the Cummins P/N is 3865405.
Next one will be a Stratapore!! Can't see paying $6 more for Mopar's paper filter than I can for the Stratapore.
[This message has been edited by Rattlin (edited 03-31-2001). ]
Mike,
Here is the best post I've seen on the oil filter question yet... .
_____________________________________________
posted 02-09-2001 04:37 PM
As an update to Mick's post, let's go back to Issue 30, page 55, for details on the
24-valve oil filter progression. We start with a reference back to Issue 26, page 28, and a discussion of the details of the thicker filter shell and threaded nut assembly/thicker rubber sealing gasket. With the hardware changes, the Mopar/Fleetguard part numbers were superceded (new part numbers LF3885/5016477AA). Then came the change to the composition of the rubber sealing gasket. Again, the Mopar and Fleetguard part numbers were superceded; new number were LF3935/501647AB.
The latest change to the oil filter is applicable for all 24-valve engines and affects the rubber sealing gasket retainer. The revised gasket retainer will lower the torque necessary to remove the filter.
The gasket was previously wedged into its retainer. When the filter was installed, the
gasket would rub against the filter head as it was turned into place. This caused excess
removal torque. The revised retainer allows the gasket to float in the retainer and thus
lowers the removal torque. The revised part numbers are LF3959/5016547AC.
To be up to date and "technically correct," the number you should use for all Cummins
engines in Dodge applications is Mopar 5016547AC.
As we noted, the 5016547AC crosses over to the LF3959. Also, as noted in the Geno's
Garage catalog, they have a large quantity of the LF3959 filters on order, but are waiting
on delivery from Fleetguard. Fleetguard currently fills orders with the LF3935 and likely will continue to do so until the supply of LF3935 is exhausted. Please note that the Fleetguard factory is located in Cookeville, Tennessee - possibly the location Alan Reagan mentioned in the earlier post?
If a customer wants the benefit of the internal Stratapore filter media, the LF3959's Stratapore crossover equivalent continues to be the LF3894.
Note that unlike the supercession of numbers LF3885/LF3935/LF3959, 501647AA/AB/AC,
the part number LF3894 has not changed as time has passed. Rather than change the
part number, Fleetguard made the effective rubber seal composition and seal retainer
revision without changing the part number of the LF3894. Thus, unless Fleetguard makes
an unexpected part number supercession, LF3894 is the correct Stratapore filter for your 24-valve engine or 24-valve HO engine.
To be "technically correct," however, that is not the right filter. 5016547AC is the correct filter.
Clear as mud?
Robert Patton
TDR Editor
Mick
<font color=blue>
2001. 5 2500 ETH/DEE, QuadCab, 4X4, SB, LSD, 3. 54, SLT+, Sport, Intense Blue PC/Agate, Tow Package, Camper Package, 'DC' Bed Cover, Sliding rear window. Totally STOCK!!
On Order 4/28/00
Arrived 9/14/00 !!
My Truck
[This message has been edited by Mick2500 (edited 03-31-2001). ]
DeepSix:
The "AB" mopar number is a correct number for our use, but due to the o-ring gasket being determined as the root cause of the extreme tight oil filter problem . . there has been a revision.
Page 55, lower right paragraph of TDR issue 30 notes for mopar the revised number is 5016547AC and for fleetguard LF3959.
You can use the ones you have . . no difference in the media between the "AB" or "AC" from what I've read.
Michael
00 Driftwood 2500 ST QC ISB LB 5spd 3:54 LSD Tow & Camper Groups . . SunnyBrook 33FKS Travel Trailer
my photos
[This message has been edited by madams (edited 03-31-2001). ]
Deepsix
The dealer diesel mechanic told me to get NAPA filter for my truck. He told me that it is one of the filters made that can hold up to the High oil pressure when the truck is cold and the pressure is at its highest.
NAPA Gold filters are WIX and there are a few guys that are running the WIX filters with good luck.
The LF3894 is what's on my 12v.
Ryan
