so you want a cummins in a ford cuase you think they make the best truck how about some of these posts from the thedieselstop.com. I did not have to dig far to find problems that has nothing to do with the POS 6. 0 onlyh to do with the quality of their truck this will make you rethink the F factor all together even if F did have a cummins in them. These are some post headings with some quotes from those heading HERE YA GO ENJOY:
1. Max A/C only blows cold?
2. Trans down
3. Checked wire harness for rubbing
quote from post "The harness is a mess there is no way in hell it can make more than 100k before issues arise from its routing,"
4. tow/haul kicks in by itself. Anyone have this problem?
5. Transmission pause and upshifting at 1500 rpm
6. Electrical problem? quote from this pos "The smoke was mostly outside with a little coming up from under the dash, all reeking of cooked electrical components "
7. What are you paying for aftermarket fuel filters? quote from post "Local Carquest priced them at $75 said he could go to $70"
8. Rear End Clunk quote from post "If this is a TSB is FMC just going to wait until the rear end falls apart before they tell anyone?"
9. Major problems with King Ranch quote and this is from a 50K truck "key in ignition not turning, on cold mornings RPM gauge/enginetem/trans temp do not work when starting truck and tghe engine light comes on. Fuel gauge light comes on and off at different times indicated water in fuel.
10. Rear axle bearing singing quote from post " I have what sounds to be the RR axle bearing or something in that vicinity singing at 17K
I could go on but i will not this ought to prove my point it does to me if you think the grass is greener on the other side go pay more for less and try it. Dodge makes as good a truck forget the engine as the other big three but not as well as the foreign competition. oh yea i did not go to the chevy page b/c i dont even consider their rig to be a real work truck with ifs bottle top heads and low rider stance. I would have to spend 3000 on tires and a lift kit before i could even be happy with the outside of the truck forget the engine and quality. GMC maxipad naaaa not going to go there. Ford is Dodges only real competitor in the heavy duty market or they were before the whole 6. 0 mishap!
2. Trans down
