95 , 2500 4x4, club cab, auto with 278,000 miles. ABS light and parking light are on and now the brake pedal will gently fall to the floor. The truck will stop ok, but the pedal is going almost to the floor. Rear sensor replaced (several times), brake module replaced, and master cylinder just replaced, but still the soft pedal. Replaced the short wiring harness wire from the rear diff to first junction and found shorted wire. Brake code still flashes "3", but have not been able to find source of the "bad wire" to dump valve as noted in the trouble codes. I can live with the lights on, but the soft pedal worries me.
