This has been my experience in soft sand. It doesn't make any difference what truck you have. Power to the rear wheels, and front, is basically all that's needed. What is important is the type of tire and the air pressure in them. With the 600 / dually you'll have a tire rating of "E". The sidewall of the tire is on the hard side so letting the air pressure down so that the tire can flex is critical. Usually 20lbs or so is a good starting point. If you feel the truck is straining too much then lower the pressure some more. Gradually ! 2 lbs at a time. If you start hopping, stop. Don't dig yourself into a hole. Let the tire pressure down some more. That's the number one thing that determines whether you go or not go. Correct pressure. Gearing is also important. Low range works well for me. Don't go hot rodding around or making any sharp turns. You can pop the bead by putting too much pressue on the sidewall if you're not carefull. Going to a more agressive tread design is not the answer. You want the tires to float on the sand, not dig in. There's alot of trial and error involved, but when you get the right combination you'll do just fine. Just take it easy and watch out for glass and boards with nails in them. If you're on long Island, try going to the Long Island Beach Buggy web site. An excellent organization to belong to. Hope I've been of some help.
Dave Beck LIBBA # 1190 , Montauk Surfcasters # 73
