Solved running light problem...
now that I'm legit, what's the next step in power?
Headlight uprate limitations???
I lost a couple of headlight switches, then added a thirty amp toggle switch just for running lights. they went out again. This time I ran a ten guage wire from the battery to a fuse to the toggle switch. The from the switched side of the switch I cam back through the firewall and connected to the plug side of the bulkhead connector to terminal 26. No problems yet, but it sure is a mighty small wire handling all the running lights. Next I'm running a seperate wire and toggle switch for trailer running lights.
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, 12cm wastegated turbo (not installed), thermostatically controlled twin 14" Permacool electric fans, intercooler (installed, not plumbed), modified 518 OD transmission, Gear vendors OD controler, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chroma-colr black, black-and-red rubber rubstrip, Cummins badges, black headlights; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. Jesus saves!
Dodge wired in the front marker lights ALONG with another setup for the rear marker lights. I placed a 20 amp fusible link to the rear marker lamp wire bypasing the switch altogether. I added a stock GM relay and it works just great. Nice Not to have the switch get hot. Mike
92 Std cab. LE. 215 P-pump reman cummins motor. 5-speed, 3. 54, 105 gal Aux tank in bed. Borgeson shaft, Banks Power pack. 12cm Hot end housing w/wastegate. 4" Exh, Pyro & boost guage, oil temp guage. E-brake. Galaxy DX99V, Used as a Hotshot/express Reg. at 36,000 lbs in 48 states. Custom built DOT approved Sleeper unit. & Texas Star 400 http://hometown. aol.com/hotshothauler/myhomepage/business.html 2000, 3500 being setup for Hotshot work as we speak. 250 miles todate
jsimpson,
To reduce the amount of amps running through your switch, why not mount a relay (close to the battery) and use the switch to open or close the relay? The relay can then power the lights directly from the battery. I don't know why you would want to run a 10 guage power wire through your firewall to a switch, and then back again through the firewall to power the lights. Most auto parts stores sell these relays cheap - less than five bucks.
89 D-250 LE 5 speed 3. 55 Limited slip, K&N, straight piped, Boost/Pyro. & 16cm2 215K and still going. 91 W-250 5 speed, 4. 10 Limited slip, 16cm2, 6" Skyjacker lift, RS9000, Dump bed, 18K original mi.
