Archived Some 47re help, please.
Archived Engine won't fire...
Archived New Auto transmission, new LOUD noise at 1000 Rpm or lower!
I've, posted this in the 2nd gen engine and transmission also.
I've got a 47re in my '99 3500 that has a bit of a problem. If I take off in D it starts in 2nd gear and upshifts early to 3rd, no lock up and no od. If I manually select L it will take off in 1st and upshift to 2nd when I move the lever to 2nd and on to 3rd when I move the lever to D. If I pull the lever back to 2nd it will shift down to 2nd but it will not go back to 1st if I manually select L. I have to go to N and let it sit there for a little bit before I can manually select L and actually get 1st gear. I checked gov. pressure and it pegs my 0-30 psi gauge with no wheel speed. I tried gov. pressure check with C2 unplugged from the PCM with the same results. Can someone give me a clue as to what is going on.
Gus
On my truck with a DTT trans there is a resister installed to fool the computer. If it goes out, 2nd gear starts will happen. If you have your paper work it discusses it in further detail.
Steve
Rather than a resistor I have a box that is adjustable and the voltage is right where it is supposed to be.
Thanks,
Gus
Thanks,
Gus
I wonder why the difference of your box and the resistor on my 03?
Well I did some more reading and trouble shooting and it looks like I eigther have a bad harness between the PCM and the PDC or the PCM has failed. The transmission control relay is turned on by the PCM and it wasn't turning on so I removed the relay and replaced it with a jumper and now everything is back to normal.
Gus
