blkdragon said:
i plan on swapping a 4BT and nv4500 into my Ford Ranger 4x4 sometime within the near future and have a few questions:
1. what do i do about the slave cylinder?
2. what all do i need from a dodge cummins w/nv4500(bellhousing,flywheel,etc)?
3. do these motors require alot of electrical work to get to run?
4. would a regular clutch for a 5. 9 work?
5. how much does it cost to rebuild one of these?
6. is there a transfer case thats electric that will bolt up to a nv4500?
thats all i can think of right now. if i think of more ill post. thanks
1. Slave cylinder is no big deal, I have used the stock master cylinders in full size ford's to engage the dodge slave cylinders. You'll just need to have a line made up to connect them. Easy enough with ARP fittings and braided line.
2. With as light as a Ranger is, you are going way overkill this way, The clutch and flywheel will never wear out, you're likely to snap a driveshaft or rear end first. You'll need the dodge bellhousing adapter on the back fo the engine, the bellhousing, clutch, flywheel, starter and slave cylinder. Find a wrecked dodge and get everything behind the crankshaft including the driveshaft if possible.
3. You'll have an alternator to hook up, electric shut off solenoid, gauge sending units unless you go mechanical, and starter wiring, Don't forget a good ground cable to the frame and the battery.
4. THe clutch will work, but you're going to be hard pressed to get the room under the transmission tunnel to fit the large diameter bellhousing, a body lift is most likely in your future with the dodge setup.
5. You can get Recon engines from Cummins for about $4500 turnkey if I remember right. If you're looking for a used one, expect the typical rebuild at a qualified shop to be $3000. 00 with labor. That's worse case scenario from my experience. A cummins direct recon engine will have a core charge on all parts rebuildable, usually adding $2500. 00 or better to an outright purchase if you don't have a core engine to turn in.
6. Check with Advance adapters, you may find the transmission adapter you need to use your stock one. Do not turn the engine up, it will kill the transfer case in short order, most likely will in stock form alone.
Another solution may be a GM transfer case with electronic engagement, I have seen some SUV's with them, I haven't used this setup because we build for towing and use 3/4 or 1 ton parts out of dodges nearly exclusively. If you're worried about wiring, this will be your worst part of the job.
7. There alot of other ways to satisfy the testerone level of a Cummins than degrading the poor engine to run in a mini truck, 4wd or not :-laf How about a nice 5. 0 out of a mustang? Possibly an Isuzu diesel from their "pup" series pickups? They are excellent engines for their size and cost.
Ditto to the first reply, the dodge parts are the way to, if you have the firewall and tunnel clearance for them. If you are up to modifying the tunnel with higher and wider sheetmetal, you should be okay. Have you measured a 4bt verses a 4cylinder Ranger engine? If you have a v-6 in yours, it is even shorter in length, not to mention the 4b's height is twice that of either 4 or 6 cylinder ranger block. Radiator and Fan clearance problems should be planned for before any commitment of parts of tear down is made. You could always leave the hood off, I guess. The I-beam front end will be difficult to lower without substantial fabrication to the crossmember and frame.
Put some more post up if you get serious, I haven't bothered with a ranger yet, but would be interested to help out if you run into trouble.
