While installing the BD external trans filter one of the required steps is to remove the return fitting from the trans. When I attempted this the brass fitting that screws into the aluminum case promptly broke off flush with the trans case. I have tried a tapered easy out with no good results. The stem inside diameter is probably about a 5/16 inside diameter. Anybody have any ideas. Apparently the thread sealant from the factory was not meant to be removed.
Dave
Dave
