I have a couple of questions about my recently purchased 1999 3500 6 speed truck. It is a former hot shot rig with 100K miles on it and I was changing the fluids and filters to get it up in shape. The following are some questions I had on the maintenance as I haven't had a chance to get the service manual yet.
What is the fluid capacity of the transmission and what fluid is recommended? Is the differential capacity the same as my 97 2500 series? How can I set the clutch free play? My 97 has about 3 to 4 inches from the floor before the clutch engages whereas the 99 has about 1 to 2 inches of free travel. Can this be adjusted or am I getting due for a new clutch. Also what other maintenance items might be recommended at this time? (Grease the front and rear wheel bearings maybe?? New belts and hoses??) Does the 24 valve need valve adjustments?
Thanks for your input.
Don
Don
