2nd Gen Non-Engine/Transmission Some quick questions about gauges
Engine/Transmission (1998.5 - 2002) one tired question asked again?
Engine/Transmission (1998.5 - 2002) Codes
Today I pulled the gauges that came with my Banks Stinger, so I am looking to replace them. The boost was electrical and used the MAP sensor. The EGT was tied into the Ottomind box.
The TST box that I just installed uses the MAP sensor, so I am thinking that I will connect my boost on the compressor side of the intercooler. But I am not sure what is best.
Questions about boost gauges:
  • Connected to the compressor side, do I use the same port as the boost elbow?
  • Connected to the manifold side, do I need to drill and tap a new port in the air horn?
  • Any advantages to connecting to one side or the other?
The TST box also uses a EGT connection to enable automatic defueling on high EGT. I used the existing T/C that I had previously installed. I think I can use the post turbo T/C port in my Banks Brake if I need to, once a get another EGT gauge installed.
Questions about EGT gauges:
  • Can a single T/C drive multiple devices?
  • Does the EGT gauge require external power, other than back lighting?
  • Is the temperature difference pre-turbo and post-turbo linear?
Thanks for any replies;
Jim
Hey,
You need a boost bolt for that guage. It makes the install really easy.
My autometer EGT guage needed ext pwr as well as lighting pwr and the probe.
I can't answer your other questions.
Good luck, Jeff
