2nd Gen Non-Engine/Transmission some toys for my 01
2nd Gen Non-Engine/Transmission More Power Steering Pump Woes
looking for some insight on a fuel pressure guage, boost,pyro easiest install. also looking for a little smoke now and then. dont want to do injecters yet. just some smoke for rollin up those strokers or duracraps. you all know what i mean. thanks yall
As far as gauges go, I would recommend contacting diesel manor (www.dieselmanor.com). I got the isspro gauges from them and they were very easy to install and came with great service and great instructions. We also did gauges on my roomates '01 at the same time and they were quite easy.
Regarding fuel pressure gauges, since you have an electric lift pump you don't need a snubber but I would definitely recommend an isolator if you plan on going the mechanical route. They are really pretty easy to install and if the gauges come with directions, that should answer any questions.
Looking at your sig I would do the edge juice with attitude and have it all in 1 package too. It will be cleaner and easier than gauges and then the comp later. I wish I would have gone that route. It maybe a bit cheaper than gauges and a comp also if you shop around.
another vote for lift pump upgrade and juice w/ attitude (in that order) and you may want to consider a valve body and torque converter upgrade SOON after if not before.
good liuck, j
