This is my first pick-up trans removal. Its the first vehicle I've owned that used SAE sizes
Bear with me if you will, I have a lot more experience with MB diesels.
The trans cooler lines seem constantly in the way. For example, I discovered that the TC bolts should not be removed thru the inspection cover, there is a plate on the side that looks like I should to do there, next to the barring tool plug. But the coolant/trans heat exchanger makes fitment difficult. Will I need to move them completely away, i. e. unbolt them from the oil pan to get the trans out? Any tips?
For the crossmember, does it get completely unbolted or just unbolt the trans mount? Some of the bolts have blind heads, or just take open end of a wrench to hold on the top of the frame?
Driveshaft. I removed the caps for the U-joint and unbolted the center support bearing, what else should I do with it to get it out of the way? Currently the end is hanging on the crossmember.
Will I need to support the engine with the trans removed? If so, what's a good way to do it? I have an engine hoist that I might could hook to the back of the motor in lieu of a jack from below.
Thanks for sharing any ideas/experience. I don't expect to get terribly proficient at this so any pointers to make the job go smoother would be appreciated. Unfortunately I didn't get the shop manuals yet.
Brian
Brian
