Also, the VP-44 injection pump has an internal pump to supply the injector side of the pump. That is why some have seen negative pressures (Big Saint for one) when their Lift Pump died. As has been mentioned before, the pumps job is to pump, not suck. The lift pump sucks as a result of the tank being too far away and below its location on the engine. Also, when the fuel level in the tank goes down, the pump has to work harder to get the fuel from the tank. Since the fuel lubricates the pumps, fuel starvation also equals lubrication starvation. As a result of all this, some have opted to either relocate their lift pump back by the tank to alleviate the suction problem, or they have added a pusher pump.
