Hello, my name is Ariel, i have a Dodge Ram 2500 2008 cummins 5.9 and 48RE transmission, now has 100.000 kilometers on it, first bands adjustment and second oil changes, i have an issue with it last weekend when i decided to make that "easy" work, first of all i adjusted front band (loose lock nut and tighten adjusting screw to 70 in-lb and then back off 1 and 3/4 turns, finally tighten lock nut and holding adjuster at the same time at 30 ft-lb and done this part), then remove the pan and old filter, so, now time to adjust the rear band(loosing the lock nut and tighten the adjuster to 72 in-lb and then back adjuster 3 turns and tighten lock nut at 25 ft-lb while holding adjuster in place and rear band done, new filter, new atf+4 oil, till here all fine, the gears engages nicely and softly, but.... when i put the shifter lever in 2 (between D and 1) before engage the 2º, the transmission make a hunt, when 2 is enagged the transmission goes fine, but in 1º from cero km/h till engage the 2º gear seems like move and leave and then move again, the official chrysler service tec said me that can be the rear band that it is too tigh, but i would like your opinion, advise and/or your recommendation,
the transmission before service work perfect,
i'll thank you very very much your words.-
