BigPapa
Well, from some previous threads I figured I had a "fuel knock". I have a '95 that came stock as an auto that I converted to a 5-speed. It has 200K miles. It has been well cared for, oil changed every 5K miles, Rotella, Fleetguard, never pulled anything heavy or been run very hard. It was stock except for exhaust and a BHAF until I installed a used set of 215's that I had cleaned and tested trying to get rid of the "fuel knock". It is most noticable at around 1500-1800 RPM on level ground with light throttle, just enough to hold speed. It's worse before the coolant temps come up. Seems to go away under heavy throttle and deceleration. Sounds like a rod to me. Here's what I've done so far:
Only thing left fuel wise is benching the pump and timing. I really don't want to do the timing first since that will be done when the pump is removed, but I don't want to spend (read "Don't have") the $400-500 to bench the pump if it's not necessary.
Am I chasing the proverbial goose? If it is a rod, can I change rod bearings by pulling the oil pan without pulling the motor? Should I attempt a rebuild or go with a reman short block?
Thanks,
Scott
- Changed fuel filter.
- Adjusted valves, none were seriously out.
- Cut the last oil filter apart and spread the element out, no visible metal even with a magnifying glass.
- Installed a new overflow valve, spring was VERY short.
- Installed new transfer pump, did get rid of a nagging "tapping" sound.
- Removed the fuel heater, leaking fuel at electrical connector.
Thanks,
Scott
