I recently located and bought a used 07 Ram 2500 with a 5. 9 and 48RE trans and starting to change all the fluids. I'm at 54k miles since buying it with 52k miles and it has not seen any heavy towing, but the transmission needs the fluid/filter changed. I've noticed a few quirks in how my truck shifts now - doesn't upshift all the time under light throttle until I back off slightly or it may not want to downshift unless I get agressive with the pedal. Also noticing a little difficulty getting the parking P to light up when shifting to park (parking pawl appears to engage but may have some adjustment to do with the linkage/cable).
I've reviewed several posts about the updated governor solenoid and pressure transducer and plan to upgrade those as well as adjust the bands when the pan is off. It appears the big question I have here comes down to this - what is the latest regarding the solenoid - is there really a big difference in the newer Borg Warner 50185 vs the GM upgrade which includes the machined block?
I've used used Transgo kits in past transmissions from Ford, GM and Mopar to improve some of the shortcomings and always had good results. Looking at other improvements available for the 48RE, I saw that Sonnax has a Sure Cure kit #SC-46/47RHE which appears to address some of weaknesses of the 48RE - I'm primarily interested in improved lube and cooling and preventing premature failure. There also appears to be other fixes that Sonnax has such as improved servos, accumulator piston improvements, etc.
At a minimum, I'm planning to do the oil (complete flush), filter, solenoid and sensor, band adjustments and drain plug for the pan (focusing on what I can improve but no plans to remove transmission). Has anyone used the Sonnax Sure Cure kit or any of their improvements? Thanks.
