I am some what new to this so help please. Mine is a 2007 3500 FWD, I pull a RV, 16,000 lbs, and it's completely stock, does a great job. Until the tank gets to 3/8 and it seems to run out of fuel, always starts again after some cranking, long enough for me to find a fuel stop. I know Dodge has had lift pump issues and I know it could be a screen contamination issue. My question is how should I proceed, thought about installing a pressure gauge off the filter, or do I need to go ahead and drop the tank. Also if the pump is at fault what should I replace it with? Thanks again for any and all advice.
