I decided to pull the carpet up in my truck and add some sound proofing material and to my surprise on the drivers side the underlay was soaking wet. Removed the side panel with the air vent and noticed that the foam seal that goes between the plastic housing of the vent and the side metal panel was pretty well useless. I am fairly confident that is the cause of the leak. I will replace the seal and put the panel back on and then use the hose to confirm if that was the problem. I also pulled the cowl grill by the windshield wipers to get a better look, but couldn't see anything. Any suggestions or comments will be appreciated.
Al
Al
