Source for Lubrication Engineers products
Abbott ERA Install
Blue Box HP Enhancement
I have tried doing a search for a source here, unfortunately the Forum seems to be stuck in 4 Low. Since I would like an answer before I retire, I figured that I'd just start a new thread.
Anyway, anyone know of a good source for Lubrication Engineers products? Their 80W-90 sounds like the stuff to use in our trucks' differentials.
Thanks!
'97 SLT w/NAPA fan belt
I dialed the 800 537-7683 and was given the number of a local rep. He (John Rocchio)dropped off a very well put together package of information in my snail mail box and a few days later called me on the phone to talk oil. He really seemed to know his products. I've used Redline in everything since 1977 but I placed an order with LE as I believe it may be better oil (especially in diffs) and the service is top notch imo...
2001 HO 6 speed Regular Cab SLT 4x4 3. 54 anti spin 2500. Used for the daily grind and sneaking away to some secret Baja beaches toting a cabover
There are oil reps for LE out there in everyones area. LE is in the USA and in 60 other countries. The 800 number you posted is the correct one and they would be able to send a rep out to see you or just to talk on the phone.
If you want to keep the business in the TDR then Mag-Hytec can get it for you. His number is 1-818-786-8325 or www.mag-hytec.com
LE has a minimum order of 100 lbs or 2 cases. Their cases are 24 quarts. So if you don't want to order that much at a time then Mag-hytec is the way to go. He will get you any amount you wish.
I will make myself avalable to you also. you can call me at 1-661-250-5343 or e-mail me at Kdinwiddie@socal. rr.com and I would be glad to answer your questions.
Sincerely, Kevin
[This message has been edited by Oil Man (edited 05-16-2000). ]
Sorry guys, it seems as if I typed the wrong phone number. I hope it has not caused any trouble. I have changed My phone number to the right one in the above post. The correct number is 1-661-250-5343.
I fixed my e-mail also
Kevin Dinwiddie
