Engine/Transmission (1998.5 - 2002) South Bend Clutch
2nd Gen Non-Engine/Transmission Trailer blowing fuses
I just wanted to give South Bend Clutch another THANK YOU for a great product and service. I stalled a Con O in my 01 6spd last weekend and it shifts smoother than the factory clutch from day one. The kit that SBC sells is great it has all the parts needed in it. I would recommend that if you are going to tackle this project that you either purchase or rent a transmission jack. I did not listen to the advise of others and did rent one. If I have to do it again I will. I just made a make shift transmission jack, and a couple of floor jacks, but over all not an impossible task for the less experienced. Again just wanted to say thanks to SBC for a great product. :) :) :)
When I had my SB installed the transmission wasn't even dropped. My installer (Aron Howlit) had loaned out his jack so he rigged up some heavy nylon straps & just hung the heavy thing there & pushed it back out of the way. It didn't look to easy to me but the man is an ace mechanic.
