South bend dual disk purchased, need install help
muffler sux
GDP Kit Installed
Hey guys just got my new dual disk in on tuesday with the sprung clutch disks and let me tell you that it looks awsome. i was wondering if someone could walk me through the install of one of these? torque specs would be nice to. anything to look out for would help me greatly. the truck is a 06 with a g-56. thanks
nothing to hard abouut installing. torque spec's are on the card in the box, i think 100lbs flywheel and about 25-30 pressure plate. install flywheel loctiting bolts and torque,wash all surfaces good with ether. wash pressure plate with ether use a little loctite on pressure plate bolts and torque, make sure pilot tool goes in and out freely as you tighten pressure plate. reassemble the rest of truck. have fun driving like you stole it... ... ... ..... kyleOo. Oo.
they just about covered all of the questions you had. if you run into any trouble feel free to give me a call 240-421-3363 i will be glad to walk you throught the install procedure.
great choice in clutch by the way. :cool:
thanks for the help guys. so nothing to worry about on the pressure plate. i dont have to adjust anything on that? what about bellhousing bolt torque. everything else im squared away on. thanks again
