South Bend Luc cluthc....rattling noise
Do I need the waste gate hooked up!
Sacramento and Modesto Meets
My younger brother just had a Luc clutch on a Getrag 360 installed on his 92 standard cab, by a shop here in Canada. When the flywheel went out for machining the shop said that there wasn't enough material to open up the center hole to accomodate the kevlar bushing so he installed a stock one instead. The machine shop said that there was signs the old bushing had been spinning in its hole as well. He now has a noise at curb idle, and part way into each gear. This noise does not happen when truck is cold started but developes after a few minutes. It goes away as he moves up through each gear, reocurring as he enters the next and so on. He has spoken to South Bend about this and they have tried to help diagnose. The feeling is perhaps the pilot bushing, or the input shaft bearing is the cause. He is taking it back in a week monday so any ideas would be greatly appreciated before he pays more money to go on a rattle hunt. BTW he says he's never had a smoother clutch than this one. It hooks up great.
What do you all think????
Thanks in advance guys!!!!!!
93. 5 D250 4X4,HD Spring Pkg, Rancho 7000's, Rear Swaybar,Dual Shock Front Stabilizer,BD Injectors,31/2" Mandrel bent exhaust,16cm 'Hot End',Modest Pump Tweaks/Timed,K&N Air,Isspro Pyro,Tach,transmission Temp,Auto Meter Oil Filled Boost Ga. , 3:54's, 4 Speed Auto, Clubcab, Aftermarket Reclining Buckets w/ctr Drop Down seat/console, Black over Silver, 21psi,285-65R-16's,American Racing Clear Coat Mags, Amsoil 15W-40HD Marine,12,000 lb. Warn Winch,KC Spots. 97,000 Kms.
[This message has been edited by BushWakr (edited 01-29-2001). ]
