Southbend Clutch Pressure Plate Cover
Mach 3s at altitude
Santa Claus came in April!
I'm installing a Southbend Con O clutch in an engine that was formerly an auto. The shop manual seems to show bolts without washing for holding the pressure plate cover on, but I need to be sure.
What grade are the bolts holding the pressure plate assembly to the flywheel and do they require washers (flat or split)?
Bolt dimensions would be useful as well, but I can probably figure that out.
Get bolts from Dodge. They have washer heads, grade 8, with shoulders to index the pressure plate with recesses in the flywheel threaded holes.
