OK fellas,
Purchased and had professionally installed this DD clutch from Southbend. 3600# pressure plate is a stiff clutch. When this clutch engages it goes, but there is no "riding" the clutch. Either your grabbed, or not, made for a pretty interesting hill start. Rattles at idle WITHOUT the clutch pushed in. Actually is very loud, bordering too loud. Does not make any noise at all if I hold the clutch in at idle. When merging on the highway and pushing to 3000 RPM, everytime I push the clutch in I get this rrrrrrraaaammmmmpppp sound for a second as I push the clutch in, then goes away until the next shift (repeat). Pushing the clutch down it now squeaks. The hydraulic line for the slave is tight, maybe too tight (transmission shop was afraid it was going to work itself apart with the engine torquing back and forth over time). Going to get some getting used too, if you asked me right now I would say a little dissapointed. Alot of money invested here, don't know if I am going to like this. The wife cannot drive the truck anymore because the pedal pressure is too much (yes, she is 100 lbs tiny thing). So, overall is this what you guys experiences have been with this clutch? 1. Noise at idle, 2. Sound everytime you shift at higher RPMs, 3. Squeaking pedal? Or is this just the clutch breaking in? BTW, the transmission shop said this was a good looking, heavy duty clutch, which I keep reminding myself. But I have gone from a truck that I could order drive up in without shutting the motor off, to a truck I need to shut down to hear someone trying to talk to me with my windows down. I was told by Peter that at SBC that the noise should only be when holding the clutch down, but it was the opposite. He laughed, said every truck was different, and that it was a matter of time before the rattle would be when I held the clutch down? Experiences, thoughts? Thanks for the inputs fellas,
Shane
