I will try to keep this short as possible. My 04.5 with NV5600 could slip the stock clutch rather easily while climbing grades with my trailer in tow. Decided it was time for a replacement. After asking many and reading many reviews I ordered a SouthBend ConOFE.
The clutch was installed one week ago by a Mopar master tech / head diesel tech at a very well known large dealer. He does 2-3 clutch jobs a week. I ordered the Clutch kit through a very large vendor and it arrived to me days later including a new SouthBend Flywheel that I also opted for instead of resurfacing mine. The kit MU 13-1. 375 CONOFE. All looked well with the clutch and the install went as it should except for one thing.
SouthBend provides a Starter Spacer that is needed when using SouthBends flywheel. When installed it seemed as if it is to thick. The teeth on the starter almost do not want to engauge the flywheel all the way. When seeing this we then made a few phones calls and were told that the fitment of this was correct and to go with it. Install was finished and the clutch was broke in properly with 200 easy stop n go miles. The clutch now has 350 miles on it and I have yet to put my foot into it.
The clutch feels great. Pedal pressure is the same as stock and engaugement is only slighty harsher. The one large downfall of the "new" disc design from SouthBend is the Gear Lash noise when letting the pedal out when the trans is in nuetral! I mean it is LOUD and annoying! Sounds like something is broke!
Today the truck left me stranded!
All has been well but when I went to re-fire all she would do is starter grind! God Awful noise! Starter bolts and all are still tight and nothing has come loose. All teeth have now been eaten off the bendix of the starter!! #@$%!
I had a bad feeling about that spacer and the fitment, but after being told it is the spacer that is needed I gave in and used it.
I have left a voicemail with Peter at SouthBend and hope to hear from him tomorrow and what needs to be done to fix this problem. I will update with the outcome.
